586,047 active members*
3,859 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 15-M OT007+OT008 Overtravel (HARD)
Results 1 to 6 of 6
    May 2021
    12
    Hello!
    I have a niigata hn50b horizontal machining center with Fanuc 15-M controls. I've read through every post i could find on the subject and tried every solution suggested with no luck, so please if you have any ideas i'd love to hear them.
    The other day when loading a program through the rs-232 the machine completely shut down. On reboot i got a "Ram parity (BASE0)" error. After re-entering all parameters etc that error message was replaced with "Overtravel (Hard)" on all axes + and -, see pictures attached. I have checked every fuse (i believe, if there are some hard to find ones let me know!) and i have power to the OT switches based on the fact that they apply emergency stop when manually pushed. I can not move the machine axes at all, regardless of mode, but the hydraulics will start.
    I have moved all the axes off the switches by hand and checked in the control that these switches are not activated. So what could cause me to still recieve this error message? Any specific parameters that i should double check?
    Could the BASE0 board need replacing even though the error regarding it no longer shows? If so, how to i check if it's fried?
    Thank you and Merry Christmas to all!
    Apr 2009
    1379
    Re: Fanuc 15-M OT007+OT008 Overtravel (HARD)
    Did you re-enter the PMC parameters? They are completely separate from the NC parameters. Is your ladder running?
    May 2021
    12
    Seems i have not. I don't have any backup of these PMC parameters, is there any way to figure out what should be entered? Can't find anything in my hardcopy manual, might just be because i don't know what to look for though.
    Ladder is showing but doesn't look quite right, probably because of missing PMC parameters then.
    May 2021
    12
    Machine is a Niigata HN 50B #25530
    Apr 2009
    1379
    There are 5 types: timers, data tables, counters, keep relays and positioning data. These are often included with have a printed ladder. Positioning data only when there is a positioning module (rare).
    I have some backups of Niigata mills that I worked on ~20 years ago, bu I don't know the exact machine model. Send me an email [email protected] and I reply with the pmc parameter that I have.
    May 2021
    12
    I do have a printed ladder in the hardcopy but no PMC Parameters unfortunately.
    I've sent you an email, thank you!
  1. ALARM OT007 +OVERTRAVEL HARD
    By KHOATRANNGOC in forum Toyoda
    Last Post: 09-23-2020, 01:11 PM
  2. Replies: 5
    Last Post: 10-12-2013, 02:23 AM
  3. Fanuc 11m OT008 -y axis over travel alarm
    By cjfisher in forum Fanuc
    Last Post: 10-10-2013, 10:28 PM
  4. Replies: 4
    Last Post: 08-20-2013, 06:16 PM
  5. Fanuc 10M overtravel (hard limit) alarm
    By CNCturtle in forum Fanuc
    Last Post: 05-22-2012, 09:59 AM
