586,512 active members*
3,726 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Camaster > Camaster stinger 1 off 20 mil in x axis, can't get support from mfg
    I've adjusted the resolution, it appears spot on. When routing out 4" test squares, squares close to x0 will be nearly spot on in size, but squares close to xmax exceed the dimension by 20 mil. What can cause this?
    I've removed the rack for the rack and pinion and its curved about 1/8". The holes for the rack are also following this curve in the gantry. I don't think this is the issue but it might be part of it?
    Quote Originally Posted by KT88saturate View Post
    This machine has had multiple issues with motors failing and bearings going out. I wonder if it's related somehow? It's only 9 months old.
    Re: Camaster stinger 1 off 20 mil in x axis, can't get support from mfg
    MFG came out and replaced the gantry. Somehow it was warped.
    Thank god I didn't buy an imported machine.
    May 2018
    85
    I had a Stinger X3 and had the exact same problem. One side of the table cut dead-nuts and the other made parts too wide by about 0.020". Resolution measured by a ruler was spot on and repeatable. Chased rabbits with CAMaster for a year before I stomped my feet and made them fly a technician out, he spent two days scratching his head. Then right before he left for the airport, he put a straight-edge on top of the guide rail. It rocked back and forth like a see-saw with about 0.015" daylight underneath. To their credit, they sent a new gantry and flew another technician cross-country out to install it.
    The problem is that the Haas they use to mill the gantry beam isn't wide enough to run it in one setup. They run half, then shift it over and index. If this isn't done perfectly the rail datum won't be straight.
  1. Camaster Stinger III for sale
    By michaeleecobra in forum For Sale Only
    Last Post: 09-07-2020, 04:31 AM
  2. CAMaster Stinger 1 or ShopSabre 23 Warning - Long post
    By JustTheDad in forum Want To Buy...Need help!
    Last Post: 11-21-2018, 05:41 PM
  3. ShopSabre 23 or Camaster Stinger 1 ?
    By Tim Sewald in forum Want To Buy...Need help!
    Last Post: 02-20-2018, 03:50 PM
  4. Replies: 3
    Last Post: 08-09-2013, 04:40 PM
  5. CAMaster Stinger
    By Cut to the Bone in forum Camaster
    Last Post: 11-18-2010, 12:24 AM
