586,094 active members*
3,913 visitors online*
    Jul 2009
    15
    440 vise alignment key?
    I just got a 4" Tormach vise for my recently acquired used 440 and found to my dismay there were no alignment keys, do I have to make them or?
    15362
    Re: 440 vise alignment key?
    Quote Originally Posted by jabingb View Post
    They are not normally needed, having a key can sometimes prevent you from indicating the Vice true to the axis. Having a Key does not automatically align the Vice true to the axis.
    An Indicator is all you need to set your Vice up.
    Mactec54
    Apr 2014
    345
    I’d say ditch the keys. I’ve had a few light crashes that just moved the vise instead of trashing something. If I had vise keys that could have ended badly
    Takes me 10 minutes tops to get 4 vises aligned to each other within .0005”. Only a few minutes for one.
    Takes much longer to actually get the table cleaned and deburred properly.
    When I first started I thought vise keys would be a great idea but now I realize they are not really needed at all.
    Jul 2009
    15
    Both of you, good points , the idea of lack of keys preventing a more serious incident has merit, thx.
    Jun 2005
    656
    Depends a bit what you do... if you're constantly swapping vises and indexers and such around that don't need to be swept in perfectly, keys can make that faster and easier, but for the most part they aren't necessary, so I'd suggest starting without them and then decide if you want to make a set. Most off-the-shelf keys don't fit Tormach T-slots anyway.
  1. Replies: 0
    Last Post: 12-22-2021, 08:35 PM
  2. VH-5C Alignment Key removal
    By rwskinner in forum Fadal
    Last Post: 10-01-2019, 10:16 PM
  3. Can't get a straight answer on this vise. TTC Super Precision Toolmakers Vise
    By l u k e in forum Work Fixtures / Hold-Down Solutions
    Last Post: 05-03-2016, 06:13 PM
  4. Oval part alignment in vise jaws
    By jlembas in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-26-2010, 04:56 PM
  5. GB alignment key sheared off!
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 08-03-2010, 02:37 PM
