586,058 active members*
4,286 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Tips about best adhesives and finishes for foam?
    Feb 2007
    10
    Hi guys!
    Does anybody have any experience to share about good adhesives to use on Styrofoam for signage and decorative columns and mouldings?
    Anybody want to share info about how to get the best glossy finishes on styrofoam signs?
    I'm starting out so I need a lot of input...
    Thx!
    Feb 2006
    794
    I've worked on foam for model airplane wings, Its not quick, but try Gorilla Glue ! it works with water and foams into the foam base and makes it strong. also you can spread it thin surface and cover it with plastic and weight and it will produce a surface and toughness that is hard to beat, and may allow more paints to be used in finishings of even some solvent products. another would of course be good ole tight bond. but not near as good
    Don
    IH v-3 early model owner
    Boggy,
    we use a product called Premierbond P60. I believe it is made by Westech. Its an aerosol or a cannister type spray gun applied. Westechl
  1. 3D topographical map routered out of foam foam
    By 3Dmap in forum CNC Wire Foam Cutter Machines
    Last Post: 08-26-2007, 01:55 AM
  2. anybody compare HT finecut tips to TD 1Torch tips for dross?
    By Knut in forum Waterjet General Topics
    Last Post: 09-29-2006, 07:17 PM
  3. Drafts: Tips for vendors and tips for RFQ writers...
    By InspirationTool in forum Employment Opportunity
    Last Post: 12-21-2005, 03:44 AM
  4. What kind of cutter finishes titanium well?
    By cjs83 in forum MetalWork Discussion
    Last Post: 08-03-2005, 04:06 AM
