586,377 active members*
3,318 visitors online*
Thread: Tool measure
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Aug 2020
    131
    Re: Tool measure
    Can you post your gcode that you used for testing?
  2. #22
    Feb 2011
    138
    Re: Tool measure
    yes, here are 3 files, 2 where error come out at 3 tool and test file
    Attached Files Attached Files
  3. #23
    Feb 2011
    138
    Re: Tool measure
    It looks that there is lack of time, still problem with tool change perexist.
    Now I have question: Is it possible to make TNG start up always with "Machine/Motors/Motors Enable" no checkbox (Off) and some notifications come up? When confirmed motors will enable
  4. #24
    Feb 2011
    138
    Re: Tool measure
    I am not a "code" man, so I have modified "Expr.txt" file:
    Can please someone take a look to my "masterpice" ;-)
    #OnInit
    print('Expr: OnInit');
    cmd("Machine.Output", 0 ,1);
    cmd("Machine.Motors.Motors_Enable", 0);
    print('Motors OFF');
    msg('Motorji izklopljeni! Vklopi CNC in potrdi');
    cmd("Machine.Motors.Motors_Enable", 1);
    print('Motors ON');
    Is this ok or shoud be done somewere else in TNG?
  5. #25
    Feb 2023
    Re: Tool measure
    Just saw this post. I have exactly this problem as well. First and second tool are fine (Z as expected) On the third tool change the tool is measured, then on the first move following the M6 it resets the work position/tool offset. At that point I stop the cycle, remeasure the work offset and restart the cycle.
    However, the display now shows the tooltip significantly below the work while cutting a the corrected work height.
    My tools are held in a collet and must be measured on each tool change. I do not use a tool table in PlanetCNC.
Page 2 of 2 12
  1. Tool Measure nk105 Weihong
    By electracks in forum Chinese Machines
    Last Post: 08-06-2019, 09:34 PM
  2. Replies: 1
    Last Post: 05-09-2017, 05:10 PM
  3. tool change and measure tool lenght, macro?
    By Charon in forum Mach Wizards, Macros, & Addons
    Last Post: 03-20-2012, 06:56 PM
  4. Offset, measure the first tool and second tool
    By domax in forum Daewoo/Doosan
    Last Post: 12-30-2009, 05:20 AM
