Hi folks,
I have an old dynapath delta controlled hurco open bed mill that I have known needs a new set of spindle bearings and a taper grind. Its gotten bad enough ive had to stop in the middle of a job to address it.
Problem is, I didnt think I was going to have problems with pulling the spindle but its getting stopped after the first bearing is visible and i’m not sure what could be getting hung up.
Ive got the nose collar spun off obviously and the small set screw is out and it will freely extract to this point, but it feels like something is hitting a hard stop at this point.
Admittedly this is the first 30 taper spindle i’ve pulled so i’m worried it might be slightly different than the bridgeport style stuff ive done in the past.
Has anyone pulled an iso30 spindle out of a bridgeport style head before and may know whats going on?
Nate
