586,069 active members*
3,793 visitors online*
    Dec 2021
    Help , cnc moving randomly
    Hello
    I Have a new machine Chinese cnc, I am using ncstudio software, but I some times facing a problem, it's moving randomly and making a noise, mostly happing when I start ncstudio and some times when I working on project, I attached a video of problem on youtube
    any one here face the same problem ?
    Feb 2011
    7
    Re: Help , cnc moving randomly
    Random un-commanded movement of one or more axis can be caused by electrical noise from the spindle VFD (variable frequency drive). The first thing I would do is remove power from the VFD only and then start the software and run a program without the spindle. Try that multiple times. If there are no random movements, then it's likely that it's a noise issue. But, there can be other causes. Check all the wiring screw terminals for the motors and drives to make sure nothing is loose.
  1. Replies: 0
    Last Post: 08-15-2016, 06:14 PM
  2. axis not moving Only DRO moving on mach3 screen for cnc router 6040
    By bingaom in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2014, 08:54 AM
  3. CNC Router Table Randomly Pauses
    By cryptodecals in forum Commercial CNC Wood Routers
    Last Post: 05-12-2014, 10:26 PM
  4. Replies: 2
    Last Post: 11-14-2013, 12:21 PM
  5. CNC Plasma - Moving Gantry vs Moving workpiece?
    By ESDave in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-23-2013, 11:53 AM
