586,060 active members*
4,282 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > PM25-MV DC Motor controller
    Hello all! I am well along in the process of converting a PM25-MV to cnc. All that is left is to figure out the spindle control. I am using a acorn board, but I unfortunately do not have the original DC motor controller that came on the mill. I was wondering if there are any off the shelf drivers that would work with the 750W motor, and take a AC input. As well as is able to take the 0-10vdc spindle control from the acorn. I have been having a real tough time trying to find something, and have reached out to PM for a replacement, but would really love something a bit more purpose built vs hacking together the PM25 board with a isolator.
    Thank you very much for your time!
    Jericho
    Feb 2018
    40
    Re: PM25-MV DC Motor controller
    I have this; Franco on the Centroid forum has a PM25
    Yeah I have seen that one, I don't have the original speed controller so I need to replace that with something as well. I was hoping there was a option that combines both the isolator and dc controller itself!
    Feb 2018
    40
    Look at the KB-SI-5 which I believe is an isolator that attaches on top of a KB DC motor controller
    Awesome, so its probably the same dual pcb situation as using the stock controller. I sent Galco sales a email, hopefully they can give me a hand!
    Thank you for your help!
  1. PM25 controller wiring
    By rschwarz in forum Benchtop Machines
    Last Post: 07-06-2022, 03:05 AM
  2. PM25 motor shaft size?
    By patrick31 in forum Benchtop Machines
    Last Post: 08-21-2021, 07:12 AM
  3. PM25 controller pictures
    Last Post: 11-14-2020, 09:59 PM
  4. Replies: 2
    Last Post: 05-22-2019, 06:41 PM
  5. DC Motor Controller & Driver 2hp ( 2kW ) Treadmill Motor
    By hesham morsy in forum Open Source Controller Boards
    Last Post: 01-27-2014, 12:50 PM
