586,080 active members*
3,468 visitors online*
Results 1 to 3 of 3
    Mar 2011
    11
    Gas enclosed mirrors?
    So to help keep primary and first mirrors clean I was going to enclose the tube and such in a gas tight enclosure.
    The tube will be on the gantry and only the final optics will be flying back and fourth.
    Would argon be a good choice?
    Or would I be better off just flowing clean compressed air over them and not make it gas tight?
    Newbie and my laser is open and wanted to limit damage to mirrors etc. when used by lazy (me) operators who forget to clean primary mirrors often.
    Slam don't want dust to settle on mirrors between uses so I only have to clean the flying optics before each use.
    Go easy if I am way off just tell me it's a bad idea and why.
    Thanks so much JC
    Jan 2008
    1529
    Re: Gas enclosed mirrors?
    How are you going to enclose them? Won't you then have an enclosure that the laser will have to pass through? The enclosure can just get dirty then
    Mar 2011
    11
    Quote Originally Posted by pippin88 View Post
    Yes. I will have a window at the end that is easy to reach and clean. the laser is gantry mounted so I will only have the flying optics and the gantry window facing the optics.
    At least thats my idea.
  1. Anyone have experience running gas shielded flux core without gas?
    By DarrellCurry in forum Welding Brazing Soldering Sealing
    Last Post: 07-06-2020, 01:14 AM
  2. Triangulation Help Please.. Pic enclosed
    By R5P7Duster in forum MetalWork Discussion
    Last Post: 03-07-2011, 12:52 AM
  3. volume enclosed into part
    By rpais85 in forum Solidworks
    Last Post: 02-18-2011, 10:14 PM
  4. Enclosed Blowers
    By Wendekreis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-08-2008, 03:20 PM
  5. Gas engine to gas air compressor conversion
    By Tom Brown in forum I.C. Engines
    Last Post: 09-19-2006, 07:58 AM
