586,106 active members*
3,172 visitors online*
Results 1 to 9 of 9
    Nov 2020
    Reaming out holes
    Sorry this is probaly a very basic question but I am stuck.
    I am using a 6mm bit to drill two holes at 15mm centres, then ream them out slightly to 6.8mm. The first hole is fine, but as soon as it hits line 12, it travels back to the first hole to do the reaming. How do I hold the coordinates (line10) for the 2nd hole reaming action?
    Any help greatly appreciated.
    1. (Hole # 1)
    2. G00 Z0 F60
    3. G00 X0 Y0 F60
    4. G01 Z-5 F60
    5. G00 X.4 (ream out to 6.8)
    6. G03 I0 J0 F100
    7. G00 X0 Y0 Z0 (back out of hole)
    8. (Hole # 2)
    9. G00 Z0 F60
    10.G00 X15 Y0 F60
    11.G01 Z-5 F100
    12. G00 X.4 (ream out to 6.8)
    13. G03 I0 J0 F100
    14. G00 Z0 F60
    15. G00 X0 Y0 F100
    16. M30
    Mar 2009
    1982
    Re: Reaming out holes
    your line 5 and 12 are the same. It is X location. Since you drilled the next hole on X=15, the next reaming should start X=15 as well.
    15362
    Quote Originally Posted by irozak View Post
    1. (Hole # 1)
    2. G00 Z0 F60
    3. G00 X0 Y0 F60
    4. G01 Z-5 F60
    6. G03 I0 J0 F100
    8. (Hole # 2)
    9. G00 Z0 F60
    10.G00 X15 Y0 F60
    11.G01 Z-5 F100
    13. G03 I0 J0 F100
    14. G00 Z0 F60
    15. G00 X0 Y0 F100
    16. M30
    That's one crazy program, this is all you need, even this is not a normal program, I have just followed the same format as you have posted, which is far from the norm.
    ( Ream 2 Holes )
    G00Z0.
    G90G00X0.Y0.
    G00Z3.
    G85G98X0.Y0.Z-5R3F60.
    X15.
    G80G0Z0.
    G0X0Y0.
    M30
    Mactec54
    Nov 2020
    Thanks guys for taking the time to look at this, but I read the manual again and found gold. Add G12 at the bottom of each hole and it works perfect!
    15362
    What kind of control are you using, as that is a strange G-Code format?
    Mactec54
    Aug 2009
    1573
    ...Reaming was the wrong term used. Its called Circular Milling that you're using
    https://www.haascnc.com/service/code...value=G13.html
    It's also a good idea when programming to be organized and follow a set Format for each Tool..and not do it mickey mouse. Read your programming manual 3-4 times helps in the long run if, new to CNC stuff.
    Good Luck on your mission.
    Nov 2020
    I used Intuwiz
    15362
    I used Intuwiz
    That is your cam software, what is your machine control.
    Mactec54
    Nov 2007
    352
    You dont need G03 at the bottom or a hole and g00 x0.4 should be g04 for a dwell not a position move !!
  1. Reaming?
    By Ansoknives in forum Rhinocam
    Last Post: 04-14-2017, 07:51 AM
  2. Replies: 8
    Last Post: 09-03-2014, 07:55 PM
  3. Dowel Pin Holes - Reaming Questions.
    By dneisler in forum MetalWork Discussion
    Last Post: 03-31-2013, 05:07 PM
  4. Tapping/Reaming Blind Holes
    By eliot15 in forum MetalWork Discussion
    Last Post: 03-24-2011, 09:31 PM
  5. Reaming Ti ?
    By Sprew in forum MetalWork Discussion
    Last Post: 06-29-2007, 08:41 PM
