586,262 active members*
3,398 visitors online*
    Jan 2022
    MultiCam 3000
    motor fault (0x 1) XA Drive 1-faulted Axis 0 3000_545_3422_XA Count 9: Drive is OK Safety stop basis: Bad hall
    I keep getting this message at startup. Any thoughts
    Jun 2005
    1730
    Re: MultiCam 3000
    This message seems to suggest you have a loose or perhaps a Hall effect homing sensor that is going bad.
    Jan 2022
    Quote Originally Posted by CNCMAN172 View Post
    Excellent, thanks for the info. When I try to home the machine, at startup, it almost appears to try to make a rapid move then stops. I can see the Y and Z axis move, then the X axis starts to travel and that’s it….shut down. Thank you for your help.
    Jun 2005
    1730
    Re: MultiCam 3000
    Quote Originally Posted by Rusty48 View Post
    This happens because the controller starts to home and sees that the home sensor a hall effect sensor has fired meaning it is already there to it stops motion. Check the hall effect sensor on the X axis. It is either bad or it is loose and near a piece of metal causing the problem. They are not that expensive you could order a new on and you would be in good shape.
    Russ
  1. Multicam 3000 Modbus 1/20
    By CnScott in forum Multicam Machines
    Last Post: 04-27-2022, 04:11 PM
  2. Multicam 3000 shutdown
    By Lilgedahl in forum DNC Problems and Solutions
    Last Post: 10-27-2018, 07:49 PM
  3. multicam 3000 parts
    By holykatz in forum Want To Buy...Need help!
    Last Post: 05-26-2016, 09:36 AM
  4. Multicam 3000 help anyone?
    By murfeedean in forum Multicam Machines
    Last Post: 05-22-2013, 05:02 PM
  5. Need help MultiCam 3000 machine
    By Speedcab in forum Multicam Machines
    Last Post: 03-10-2012, 04:04 AM
