586,061 active members*
4,379 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Old Haas VF0 1994, problem with jumping dimmension in Z axis
    Aug 2015
    9
    Hey everyone. I have another problem with my Haas, Z axis have counterbalance , and right now when i tunrn on program after machine make it all Z axis are higher 0,3mm.
    I did program in MDI:
    G90 G43
    T01 M06
    H01
    G54
    G00 Z30.
    G04 P1
    G00 Z150.
    G00 Z30.
    G04 P1.
    G00 Z150.
    G00 Z30.
    In indicator after this program Z axis is 0,02 higher, if i turn on this program few times all Z axis move up almost 0,15mm, then i stopped it.
    If I zero Z axis it still have this 0,15mm incorrection.
    So anyone have any ideas what happends ?
    I don't understeand why when i zeroed Z axis they still have this incorrection, i think it should go back to correct position if they know when sensors are ?
    15362
    Re: Old Haas VF0 1994, problem with jumping dimmension in Z axis
    Quote Originally Posted by MarioMAX View Post
    G90 G43
    T01 M06
    H01
    G54
    G00 Z30.
    G04 P1
    G00 Z150.
    G00 Z30.
    G04 P1.
    G00 Z150.
    G00 Z30.
    This would be an Encoder problem or Encoder cable, could also be the Ballscrew or the Ballscrew Thrust Bearings, Motor coupling also, so, a few things to check.
    Your Z moves are all positive moves, Z axis moving up, nothing should change as you are moving in the same direction, you should be able to check this in manual mode with the Handwheel
    Mactec54
    May 2022
    14
    Hi, I bought a milling machine like your milling machine. Unfortunately, the parameters and all settings have been deleted. It does not run programs. If your machine model is vf-0. Please send me the general parameters and settings of the milling machine so that my machine can work again. Let me start, thanks, dear colleague
  1. HAAS VF0 toolchange problem
    By lapokerplayer in forum Haas Mills
    Last Post: 05-25-2022, 08:36 PM
  2. 1994 VF0 maintance guide needed
    By Ryan Moore in forum Haas Mills
    Last Post: 05-25-2022, 08:29 PM
  3. Haas VF0 jumping in -Y- axis - Need Help!!!
    By StealthAz in forum Haas Mills
    Last Post: 05-25-2022, 08:28 PM
  4. Replies: 1
    Last Post: 05-25-2022, 08:15 PM
  5. Haas vf0 tool changer problem alarm 114
    By nevron in forum Haas Mills
    Last Post: 05-07-2008, 08:36 PM
