586,089 active members*
3,957 visitors online*
Results 1 to 2 of 2
    Sep 2019
    7
    Morbidelli A504 Rapid wrong toolnumber
    Hello,
    I have a Morbidelli A504 rapid with a disc toolchanger.
    I restarted my machine after a lightningstrike and got everything back.
    The problem now is that it thinks a tool from position 55 is in the spindle but I only have 6 positions. When the machine itself tries to remove the tool, the disch spins and stops in between the holders, which means it cannot get a hold of the tool causing a 690 error magazine in/out.
    I can do the toolchange by manually moving the magazine in the tria menu. But when I'm done it still says tool from position 55 is in the spindle. The machine itself is running so it's just the little detail in changing tools automatically that is the problem.
    Any idea in fixing it?
    Thanks in advance!
    K-J
    Feb 2006
    19
    Re: Morbidelli A504 Rapid wrong toolnumber
    Hi KJ
    Did you get this problem solved?
    Louis
