586,115 active members*
3,516 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Could I use an Arduino Pro Micro with the ADS1115 to build a joystick?
    Oct 2016
    15
    Hello, I have a question. Could I use an Arduino Pro Micro (10bit resolution) with the ADS1115 (16bit resolution) to build a joystick (with better sensivity) that uses some hall effect sensors with magnets ? Thank you !
    Mar 2015
    410
    Re: Could I use an Arduino Pro Micro with the ADS1115 to build a joystick?
    The ADS1115 can be powered at 5V and uses i2c to communicate so it should work without any doubt.
    I don't think 12 bit resolution will do a better job because 10 bits resolution are 1024 steps. I doubt if your (a) hand is capable of moving the joystick so little that 10 bits resolution isn't enough.
  1. Replies: 0
    Last Post: 01-14-2022, 03:41 AM
  2. Pro help wanted - will pay - Pro Kit build
    By skyways-uav in forum Avid CNC
    Last Post: 02-25-2021, 09:17 PM
  3. Replies: 1
    Last Post: 03-17-2017, 11:45 AM
  4. CRP PRO 48x24 DIY Custom Build. First CNC Build.
    By OrangeClockwerk in forum Avid CNC
    Last Post: 11-06-2014, 11:58 PM
  5. Micro Machining with Vcarve Pro
    By inov8r in forum PhotoVCarve and VCarve Pro
    Last Post: 01-19-2014, 06:36 AM
