586,117 active members*
3,438 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Videos > Experiments in moving gantry design (Al, steel & epoxy granite)
    Hi All,
    So a long time ago I started making a weird gantry. Thought some might get a kick from seeing how it went together.
    It's a composite aluminium, steel and epoxy-granite beam, with cast Al endplates.
    The machine's not really finished yet so loads more testing is needed.
    So far it's looking good :banana:
    Bongodrummer - www.FloweringElbow.org
    Re: Experiments in moving gantry design (Al, steel & epoxy granite)
    PS I could really do with some advice about ballscrew protecting for this setup. I have bodged up a wiper for the rotating ball nuts of the long axis, using a glue gun 'casting type method...But it's very temporary. Am thinking the way forward will be to cover the whole thing, but how?
    Jan 2008
    1529
    Nice result! I'm keen to see more cutting results
    Thank's Pippin, yeah I need to spend some time sealing up all the ballscrews etc before I dare do much more cutting, of metals at least...
  1. Replies: 54
    Last Post: 04-20-2020, 09:54 PM
  2. Epoxy Granite / Quartz Granite Mixes & Tests
    By made2hack in forum Epoxy Granite
    Last Post: 03-19-2018, 09:11 AM
  3. Epoxy-Granite CNC Lathe Design (and Build)
    By romihs in forum Vertical Mill, Lathe Project Log
    Last Post: 02-16-2016, 06:07 PM
  4. Epoxy/Granite Gantry Router
    By johnohara in forum Open Source CNC Machine Designs
    Last Post: 09-23-2008, 02:43 AM
