586,062 active members*
4,429 visitors online*
Results 1 to 2 of 2
    Jan 2022
    Question Old Saw Blade Not Conductive Enough?
    Does anyone have an idea what old time two man saws are made out of? Our Shop Sabre plasma will not touch off on one. We cleaned the rust off it and wiped it down with mineral spirits. It still wouldn't complete the circuit. So then I got really curious and grabbed a multimeter to see if I could get continuity. Nothing, even if I scraped the probes on the blade. One of my students is trying to cut a design out of it to hang on the wall. It has to be made from some type of spring steel to be that flexible. I am completely baffled. Anyone have an idea?
    Thanks!
    Jun 2010
    4256
    Re: Old Saw Blade Not Conductive Enough?
    If the blade is steel, it IS conductive. It will be steel.
    But the surface may be passivated somehow.
    Try a bit of sandpaper or wet&dry.
    Cheers
    Roger
  1. conductive non metal material for plating?
    By manakawari in forum Material Machining Solutions
    Last Post: 09-09-2016, 01:32 AM
  2. Thermark- is it conductive after lasering
    By cnctoolman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-25-2012, 02:17 AM
  3. Need: non-conductive aluminum like material
    By Heather in forum Material Machining Solutions
    Last Post: 02-27-2011, 05:55 AM
  4. Replies: 4
    Last Post: 01-02-2009, 10:55 AM
  5. Alternatives to precise soldering - conductive plastic?
    By medved in forum CNC Machine Related Electronics
    Last Post: 03-19-2006, 04:00 AM
