586,113 active members*
3,485 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 5 axis ebay BOB or RS 485 control with mach3 and Huanyang GT VFD ?
Results 1 to 9 of 9
    I have a harbor freight 33686 round column mill that I have a Paul CNC setup on that works great for me. I will be switching to ballscrews and VFD setup. Brand new to the VFD stuff, so wondering which setup is best? Been searching and finding bits here and there, so I'm sure i'll have follow up q's, but any help is appreciated
    HY GT model - GT-2R2G-2
    Leeson 115826 3ph 2HP 220v 1725rpm motor
    Jan 2018
    1516
    Quote Originally Posted by flinttownchopper View Post
    Does Mach3 even read rs485?. It's a very old program.
    Just use the analog 0-10v
    Re: 5 axis ebay BOB or RS 485 control with mach3 and Huanyang GT VFD ?
    Quote Originally Posted by dazp1976 View Post
    I think it does, but i was thinking same thing, So this then?
    Apr 2013
    1899
    You can control the VFD with Modbus but only if your VFD understands real Modbus. Not all cheap Chinese VFD does that even if the manual states that it does. Mach3 needs a Brain file to communicate. When I used Mach I wrote a Brain file for my VFD and controlled it via Modbus. Mach can handle RS485 but that is not enough, it is just the hardware protocol. Modbus is the actual communication protol and is an industry standard. Use analogue voltage if you are not familiar with Modbus.
    Apr 2013
    1899
    RS485 and Modbus is much older than Mach3...
    24221
    I used the 'Modbus' Mach3 plug-in plug-in program from Mach3 plugin for Huanyang VFD | Le royaume d'éole
    Huanyang call it Modbus but it is a slight variation.
    Albert E.
    Quote Originally Posted by A_Camera View Post
    Thanks, that's what I figured, and I don't know a thing about MODBUS, so New BOB is probably my best bet
    Appreciate the reply. I had seen this but also read that the GT VFD's are true MODBUS insinuating that plug in won't work. Ultimately I just want to make sure one method isn't way better than the other. So if the 5 axis BOB I attached above is fine, good enough for me
    Nov 2013
    4376
    the early model Huanyang VFDs has a non-standard protocol, and that required the specialist plugin that Al-the-Man referred to. Later model (GT) Huanyang are supposedly Modbus compliant.
    The problem is the Mach3 Modbus module is an absolute dogs breakfast. I managed to get one working with Modbus/Mach3 and swore I'd never do it again.
    Mach4's Modbus module is a delight by comparison.
    Craig
    24221
    I had an application that needed to communicate with a Huanyang, after some emails with Sebastien of Royaume plug in I managed to write one such a program.
    Albert E.
  1. Replies: 10
    Last Post: 11-14-2023, 07:17 PM
  2. Replies: 41
    Last Post: 03-15-2023, 01:14 AM
  3. HY VFD Mach3 Control BOB wiring
    By dbtoutfit in forum Spindles / VFD
    Last Post: 08-04-2019, 11:28 PM
  4. Sunfar e300 settings from ebay 5 axis mach3 bob
    By tobiascourt in forum Spindles / VFD
    Last Post: 04-11-2019, 11:36 PM
  5. Replies: 3
    Last Post: 11-20-2014, 06:05 PM
