586,106 active members*
3,166 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > EMCO Concep Turn 450, no connection to ACC
    Mar 2007
    84
    Hi!
    At my work we have EMCO CONCEPT TURN 450 lathe, which started having huge problems a few months ago (since that it stands in corner waiting for a miracle ). We can't start the control program- it seems there is some problem in ACC module. What to look first at- could it be motherboard or (hopefully not ) a CF card that does not allow machine to start? Do some of You have CF card content if any?
    Thanks in advance-
    Guntis
    Mar 2007
    84
    Re: EMCO Concep Turn 450, no connection to ACC
    Ok- we have tried to start our SIEMENS 840D from control panel with removed ACC PCI card- program start up, show an error 8257 Real time module not active or PCI card not found! (of course- because it is removed) and shuts down. When PCI card is placed in ACC module and all cables are connected, in case of starting a control program, PC tries to communicate with ACC and in the middle it stops. Nothing happens there. Any ideas?
  1. Emco Concept Turn 155 ACC
    By Fire_in_the_hole in forum EMCO Lathe
    Last Post: 09-12-2022, 02:13 PM
  2. Replies: 2
    Last Post: 01-13-2017, 09:03 PM
  3. emco turn 120p with emco tronic ti control
    By rcjacob in forum Vertical Mill, Lathe Project Log
    Last Post: 03-26-2014, 05:01 PM
  4. coordinates problem on emco concept turn 450
    By oskar88 in forum EMCO Lathe
    Last Post: 10-31-2012, 07:29 AM
