586,070 active members*
3,627 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > CNC machine not cutting normaly
    Hi all,
    I have a problem, when i cut mdf board 18mm and deeping for 2mm, every time when goes around, it is back to y-axis 0, he start not from the same position. And that's every time. There is a Mach3 software show that goes to zero, but it really isn't.
    I used a Stepperoline DM542T, and a Stepperoline 23HS45-4204S engine.
    Can somebody help me? Thank's
    Mar 2008
    285
    Re: CNC machine not cutting normaly
    You would need to post you NC-Program code and cutter diameter for an analysis.
    Maybe a simple drawing of what you think you cutter path should look like would help
    Quote Originally Posted by gwood View Post
    I draw simple object like photo, on another my cnc the same g-code cutting normaly, but this new and something not good
    1227
    The part could be moving or the machine might be losing steps if you have given it a feed rate that it doesn't have the power to execute.
  1. Replies: 0
    Last Post: 05-08-2015, 04:10 AM
  2. Replies: 3
    Last Post: 09-19-2010, 02:40 PM
  3. Replies: 0
    Last Post: 09-17-2010, 09:09 AM
  4. Replies: 0
    Last Post: 09-17-2010, 08:51 AM
