586,094 active members*
3,709 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > curved measurements
    Jan 2022
    Talking curved measurements
    can someone help me to learn how in aspire 9.5 to measure an arc i make templates for projects we build and the best way to describe most of them is they are the letter u shaped I am given things like the radius and length of curve the length of "arms" the total Hight of project and the length and then I need to move them over to aspire to cut out. I have been lucky so far as i have been able to just draw my circles then guess close enough, but one day my guessing is going to ketch up to me. I have attached an image if i did it right. Thank you to anyone who can help me to learn this.
    Apr 2005
    304
    Re: curved measurements
    Be more precise on which dimensions you have.
    I can not comprehend it from your writing.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    1227
    I'd use dimension-arc to find the radius and then switch off the dimension layer when I was programming.It works for any angle between the straight sections but in the instance of having parallel straight sections,you could also use the alternative of measure-distance-horizontal and divide the result by 2 for the radius.
  1. dynatorch measurements
    By redfarm in forum DynaTorch
    Last Post: 08-27-2010, 01:09 AM
  2. Multiple measurements are ignored
    By ASMM in forum Hypermill
    Last Post: 02-12-2010, 08:42 PM
  3. sieg x2 measurements?
    By ihavenofish in forum Benchtop Machines
    Last Post: 08-13-2009, 07:13 PM
  4. Need Help with some Gear Measurements
    By Kain in forum Mechanical Calculations/Engineering Design
    Last Post: 07-17-2009, 03:24 AM
  5. Hairline measurements..
    By Rekd in forum Community Club House
    Last Post: 08-27-2003, 05:56 PM
