Hi all
Well, I purchased an SX3 and did the CNC conversion (CNC Fusion kit) a couple weeks ago. Potential problem though- wondered if there are any other SX3 users who can respond-
The Z axis gib seems to me to be installed backwards- or more to the point, machined backwards. The Z is a wedge type, and it seems like the wedge was formed by a 5 year old with an old file scraping away at a standard gib. Thing is, the wedge side is actually facing the Z column Way, and not the head. So, basically, I have a bearing surface that is about as smooth as (a piece of metal filed by a 5 year old). Since the gib is machined at the head for a special adjustment bolt, I cant just invert it- and even if I could, Im not sure that inverting wouldnt just negate the whole wedge concept- since the gib would no longer be parallel (if Im visualizing this correctly).
On the gib, there is an oil hole that feeds a slot on the opposite side of the gib. If anyone recalls, which side is this slot on (the bearing surface, or the tapered face)? And, is the bearing surface the smooth or the machined face?
Regards,
Rob
