586,121 active members*
3,156 visitors online*
    Feb 2009
    499
    Rack and pinion spring wear
    In our maker space, we have a CNC router table rebuild going on that uses the Avid motor drive and a R&P setup. One of the members wants to mount the rack with the teeth pointing up so that he can use gravity to hold the pinion against the rack. He claims that mounting the rack with the teeth pointing down and using a spring to hold the pinion against the rack will cause premature wearing of the spring. Anyone ever seen the spring wear out and need to be replaced?
    "72.6 per cent of all statistics are made up on the spot." - Steven Wright
    Dec 2013
    5717
    Re: Rack and pinion spring wear
    I suppose over a long time a spring might lose some of its spring, especially if being over stressed. But normally this would not be a problem that you would see if the spring is correct for the application. Besides, springs are pretty cheap.
    Rack teeth pointing down helps keep the crap from building up in the teeth.
    Maybe your co-member had a bad experience with a spring at some time?
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2008
    1762
    The benefits of having the teeth pointed down to help prevent debris build up far outweighs any rare, and possibly unheard of benefits of preventing spring failure.
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Nov 2015
    31
    There is no benefit to mounting that way, springs wear out from compression/decompression cycles not being held compressed. It's likely you will wear out several sets of pinion gears before you lose any appreciable spring rate on the tensioning spring.
    15362
    Quote Originally Posted by revwarguy View Post
    He may mean the wear of the Rack and Pinion; with this design both the Rack and Pinion will wear out many times before you will have any spring problems, up or down it's a bad design to start with, a fixed mounted Pinion is the best method for a Rack and Pinion.
    Mounted up or down with this design, does not change anything the loading will still be the same.
    Rack with the teeth down is the only way for a router like this, the other way would be sideways but still will get dust and junk in the teeth, so Rack teeth down is always going to be the best way.
    Mactec54
  1. Rack and pinion spring force?
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 02-14-2011, 12:42 PM
  2. Rack and pinion spring loading question
    By microdot in forum Mechanical Calculations/Engineering Design
    Last Post: 11-12-2009, 04:10 PM
  3. Rack and Pinion Spring Tension System?
    By dpaish in forum Waterjet General Topics
    Last Post: 07-16-2009, 07:17 AM
  4. Spring loading rack and pinion?
    By flash319 in forum DIY CNC Router Table Machines
    Last Post: 03-17-2009, 12:57 PM
  5. spring loaded rack and pinion
    By dgalaxy in forum Waterjet General Topics
    Last Post: 12-03-2006, 06:49 PM
