586,112 active members*
3,081 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > One tool, Multiple Offsets in Inventor CAM
    Jan 2022
    Question One tool, Multiple Offsets in Inventor CAM
    I know this has been covered before but was only answered regarding fusion 360. Is there a way to put toolpaths together from multiple work offsets to avoid tool changes. Copy and paste editing is too cumbersome and too easy to create errors.
    Jan 2018
    1516
    Re: One tool, Multiple Offsets in Inventor CAM
    I know you can have multiple 'setups'.
    So setup #1 can be toolpath in one 0 position.
    Then setup #2 can be another tool path from a different 0 position.
    Then setup #3, setup #4 etc. Can't remember if it puts them all together in one post or not.
    You can deselect 'tool change' in the tool pages.
    Sep 2017
    40
    Yes it does indeed work as dazp1976 says. I use Inventor CAM and you can many setups with different zero positions and it will post as one continuous file it only stops if there is a different tool otherwise it just runs beautifully.
    Mar 2008
    683
    Quote Originally Posted by dazp1976 View Post
    Ditto. Select the setup folders and post. The G5x offsets will be posted with the same tool. Alternately you can use the same setup and use the "transform toolpath" options but you will have to know where your setups are outside of your machine offsets.
  1. One tool for Multiple WCS Offsets
    By Antvillareal in forum Autodesk CAM
    Last Post: 07-28-2021, 11:05 PM
  2. Multiple offsets for the same tool in RapidTurn
    By BanduraMaker in forum Tormach PathPilot™
    Last Post: 04-29-2019, 06:20 PM
  3. Replies: 2
    Last Post: 07-01-2016, 02:32 AM
  4. how to assign tool multiple offsets 640m
    By kentucky jeremy in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-18-2015, 01:22 AM
  5. Tl-25 multiple offsets for same tool Help
    By mkmk123 in forum Haas Lathes
    Last Post: 11-24-2007, 01:22 AM
