Originally Posted by
joeavaerage
Any diameter rod would be fine, I doubt you'd ever wear out the rod, but may wear out the bearing if dust and other contaminants get in there on a regular basis.
The real problem is stiffness, or rather the lack of it. If you take steel bar, say 1" in diameter and a yard long, support it at each end, how much force would it take
to deflect the centre of the bar by 20 thou?. Not bloody much I'll be bound. This will happen when your cutting, the cutting forces will deflect the rails and all accuracy
is lost. If your rails were 12" or less I'd say you would be OK....but 42" forget it.
Your rails, either square OR round must be mounted along their length or they WILL deflect. If that means you have to get the steel table machined flat, that's whats you have to do.
There is a reason that many people on this forum talk about methods to reduce or eliminate the requirement for machining, or by design reduce the cost and complexity of that machining.
Square rails are a factor of ten stiffer than round rails and much preferred. Stiffness is the absolute minimum requirement for accuracy, if the machine is not stiff it will flex and vibrate like hell
and any semblance of accuracy or surface finish is lost.
Craig
