586,535 active members*
2,831 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Avid "plug and play" VFD knob - what is it?
    Apr 2004
    326
    Hey all,
    just received and installed the AvidCNC 4HP router with plug and play VFD cabinet. Of course, inside the cabinet is an electronic VFD, and I notice there is a "knob" (potentiometer) that is not addressed in any of the documentation.
    So the curious in me was wondering:
    1) What exactly is this for?
    2) Where should it be set?
    3) MOST IMPORTANT: Does it go to 10, or 11?
    Thanks.
    24223
    Re: Avid "plug and play" VFD knob - what is it?
    Maybe contact the manuf, and get clarification.?
    Nothing on it labeled?
    Could be the manual RPM button?
    Albert E.
    Nov 2012
    1267
    Most VFDs have a potentiometer on the front panel. Depending on the VFD settings, it either controls the spindle speed, or does nothing. Turn the spindle on, rotate the knob and see what happens.
    15362
    Quote Originally Posted by Kosh View Post
    Hey all,
    Thanks.
    Your setup will determine how the Pot works, in remote control (which most likely you are using) the Pot will not work on most VFD Drives, if you are using the VFD in manual mode (Keypad control) then there is a Parameter that you would set and then you can use the Pot to control the spindle speed.
    Mactec54
  1. Replies: 2
    Last Post: 01-08-2020, 08:33 PM
  2. Non-CNCRP VFD on Plug & Play
    By wmgeorge in forum Avid CNC
    Last Post: 12-19-2018, 10:49 PM
  3. vfd used in plug and play setup?
    By BendingUnit22 in forum Avid CNC
    Last Post: 10-17-2018, 04:54 AM
  4. "Plug and Play" CNC controller.
    By [email protected] in forum Hobbycnc (Products)
    Last Post: 10-30-2007, 08:46 PM
