586,043 active members*
3,949 visitors online*
    May 2021
    6
    Question Bridgeport EZ path lathe data sending software
    Hi all
    does anyone know what software i should use to transfer programs to the machine via RS232 port?
    any links to it would be great thanks !
    easy link seems to be the one does anyone know where i can get it?
    Jan 2014
    37
    Re: Bridgeport EZ path lathe data sending software
    you can also try FILOU-MX2
    May 2021
    6
    Great ill give it a go , do you have a safe download link ?
    Moto,
    Exit EZPath program by select 'Utils'. It should switch to a screen that gives several comm options: Z-modem, text, EZlink. Need one of these programs to talk to the EZPath. Good luck finding them, and they only run on MS-DOS 6.22.
    Regardless, RS-232 comm may or may not work on EZPath, it depends upon the software version and the pc-motherboard. if the motherboard was upgraded/replaced from the original it probably will not work, the software is incompatible.
    FYI, I worked in Bridgeport / CMS in early 90s and wrote the communication utility software. After '96 it was never updated by CMS to be compatible with pc-motherboard replacements.
    Bart
  1. Romi/Bridgeport EZ-Path Lathe serial transfer using EZ-Path Utilities
    By Moscow in forum Bridgeport / Romi Lathes
    Last Post: 06-04-2017, 04:37 AM
  2. need software disc for EZ PATH Romi Bridgeport lathe
    By CPatten in forum Bridgeport / Romi Lathes
    Last Post: 12-10-2015, 04:53 PM
  3. Bridgeport EZ-Path ROMI Lathe Software
    By dannyparenteau in forum DNC Problems and Solutions
    Last Post: 08-16-2013, 08:36 PM
  4. Bridgeport EZ-PATH S update software
    By blodnob in forum Bridgeport / Romi Lathes
    Last Post: 03-02-2013, 11:49 PM
