586,119 active members*
3,478 visitors online*
    Fanuc Robocut alpha oc wire eroder
    I have a stainless steel job that is 100mm thick with a slot going horizontally across the cut that I am making, which causes the water flow to be interrupted. The feed is really slow 0.85mm/min. Does anybody know how I can speed this up?
    May 2010
    61
    Re: Fanuc Robocut alpha oc wire eroder
    Just throwing this out there as I am new to EDM but could you possibly clamp something over the sides of the slot to hold water in? Not sure if it would help or not but...
  1. Fanuc Robocut alpha oc wire edm backlash compansation
    By shabbirabbas in forum EDM Discussion General Topics
    Last Post: 10-03-2022, 10:28 AM
  2. Fanuc Robocut 0C Wire EDM eroder
    By lawnputter in forum EDM Discussion General Topics
    Last Post: 01-30-2019, 01:48 PM
  3. EDM Cutting Conditions For FANUC Robocut (alpha)-OC and (alpha)-OiA
    By aaronell in forum EDM Discussion General Topics
    Last Post: 11-02-2015, 07:01 PM
