I am working on a Multicam MT22 with the M23 control board. I can see the machine boot up in terminal ,so the communication appears to be correct (see below).
{17} uCito M2000 V1.77a
4M RAM installed.
Chan0: 1064960, Chan1: 384
MCIF V3.36c-GL-CNC-KN, DSP V1.03 MFG V21, KDM V3.36c (c) 1997 ETC.
Loading User INIT file.
Motion Buffer = 5000
> ack {6}A1{6}
> hpgl
When I select DNC from the control pendant and press enter I do not get a list of my files. If I have the terminal open I see {6}D0{6} each time I press DNC on the pendant. The MX32 isn't responding to the DNC request. The MX32 manual states to DNC I need V3.4 or later. The pendant displays Machine Automation v3.36c m23 i3.47 0 . I assume the 3.47 indicates it should support DNC. I have tried with both MX32 and PSS software with no response to the DNC request.
Is MX32 the correct software to be using with this machine? I also have a MT44-Plus and it uses the PSS software so I tried it first. So far I'm stumped. When I select DNC from the menu do I need to press ENTER or some other key to pull it up?
I've attached a few photos.
Attachment 475496
Attachment 475498
