586,103 active members*
3,082 visitors online*
    Feb 2022
    20
    Newbe to the laser topic forum
    Hello all, I recently upgraded from a Gravograph IS400 CNC to a Boss HP2040 150w CO2 laser
    Man what a difference!
    So many things are different so a learning curve is coming
    I will try to look over previous posts to keep my questions from being redundant
    So first question, videos and sites that talk about how they got their settings put Power and speeds in percentage yet never say what the max of each is.
    I believe that at 150w @ 33mm/sec it will fry a manilla folder
    https://youtu.be/bQTFEv7uGn0
    Your thoughts?
    Sent from my SM-G988U using Tapatalk
    Feb 2022
    11
    Re: Newbe to the laser topic forum
    hello , mainly in laser machines , you can use 3 mm acrilic as a guide of speed , 100 w laser machine can cut to a speed of 40 mm/seg then 150w speed should be around 55 mm/seg , power around 100/80 ( poer /corner power) in the case of paper, thin folder , sponge and others easy to cut speed around 100 mm/seg and cutting power reduced to 50/30
    I hope this information cand be helpfull
    best wishes
    Feb 2022
    20
    Quote Originally Posted by lasersparts View Post
    around 55 mm/seg
    Yes it does
    Only thing is that the terns are different
    I'm guessing that it is a typo (mm/sec)
    That is the stuff that confuses me
    I have 5mm that cuts fine
    I'll get some 3mn
  1. newbe needs help with china laser
    By Driven2112 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2022, 12:38 AM
  2. Newbe wanting laser cutter to make coin dies
    By doncollier in forum Chinese Machines
    Last Post: 02-18-2018, 10:17 PM
  3. my first topic - laser test for cnc
    By fcamargo010 in forum Videos
    Last Post: 05-21-2010, 03:01 AM
  4. Forum Name / Topic?
    By John3 in forum G-REX
    Last Post: 08-07-2007, 12:18 AM
