Originally Posted by
jlind54
My grbl based controller is supplying 0-5v. The vfd is set to use 0-5v reference for the speed. Turning it on and off I’m using the run/stop button on the vfd.
With min. speed set to 120 when I send M3S12000 I get an rpm around 15,600. With min. speed set to 0. M3S12000 yields an rpm of 12,200.
When the min. speed is set to 120 once I send any M3SXXXXX then follow up with an M5 the spindle will slow to 7200 rpm until I press the stop button.
Min. speed set to 0 when I send M5 the spindle slows to a stop.
