586,082 active members*
3,613 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Problem when GND XGND and FDW are connected..
Results 1 to 2 of 2
    Nov 2019
    Hi everybody, I need some help about my cnc machine, I explain me:
    First, sorry for my very good and beautiful english!!
    So, I have a BoB STB5100 and a 2.2Kw spindle with VDF Y620-A
    the setup of the VFD are okay ,I can control the VFD in MACH3 ON/OFF and spindle frequency.
    The wire connection between VFD and BoB are:
    VFD To BoB
    XGND -> COM
    GND -> GND
    10V -> 10V
    AVI - > Vl1
    FWD -> FWD or Output#1
    Now my problem is, sometime (almost all the time) when a connect my BoB to MACH3 and the VFD is switched on, I get a communication error.. sometime that work but max 2min. When I just disconnect the Xgnd or FDW wire, thats work without problems (of course a can't turn on the spindle with mach3 but I can control the frequency speed).
    By the way when a make a bridge between XGND and FWD (means the FWD and XGND are not connect to the BoB), I have the same problem!
    I had tried to put some capacitor and diode as filter, change nothing.
    Some people know this problem??? thx
    Sep 2007
    10
    Re: Problem when GND XGND and FDW are connected..
    hi
    also i am using this stb 5100 card
    unfortunately I can't manage the 10V output.
    measuring with the tester when I turn on the spindle I do not detect any 0-10v voltage.
    some idea?
    thank you
  1. RDC6332G no connected devices !!
    By DrAhmed in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-26-2020, 04:09 PM
  2. Replies: 9
    Last Post: 07-21-2017, 02:02 AM
  3. 24v 5m led strip connected to 24v fan terminal?
    By bigz1 in forum Hobbycnc (Products)
    Last Post: 11-23-2016, 08:31 PM
  4. Haas EC-400 Auger not connected
    By hutch07 in forum Haas Mills
    Last Post: 09-22-2015, 01:46 PM
  5. CNC connected to a Mac ?
    By Erik Brinkman in forum MetalWork Discussion
    Last Post: 06-29-2010, 05:44 PM
