586,754 active members*
7,398 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Variables sub routines?
    Sep 2011
    40
    I'm trying to write a warm up program that steps through rpm values. I found you can use Variables in Section 5 LINK of the manual. When I load this into the cnc (fadal 4020 with 88HS in format 2) all I get is "ERROR" with no explanation on the MU-47 screen.
    Any ideas?
    O1001 (WARM UP)
    L0100 // Define Sub 01
    S+R0 M3 // Sets spindle speed to current R0 value
    R0+500. // Increase rpm by 500 each loop
    L0201 // Run sub 02
    M17 // End Sub 01
    L0200 // Define Sub 02 - draw two circles close to the extents of machine travel
    G0 G53 X-0.025 Y0.
    G2 X-19.975 I-9.975 F100.
    X-0.025 I9.975
    G1 X0.025 Y0. F100.
    G3 X19.975 I9.975 F100.
    X0.025 I-9.975
    M17 // End Sub 02
    M30 // End of sub section
    G90 G94 G17
    G20
    G28 G91 Z0.
    G90
    R0+500. // Sets initial rpm of 500
    T2 M6 // Put tool in spindle for warm up
    L0120 // Call sub 01 twenty times
    M5
    G28 G91 Z0.
    G90
    M30
    I've also tried reducing the program to limit what could be wrong and it still doesn't work:
    O1001 (WARM UP 10)
    # Clear (Clears all variables)
    # V1 = V1 + 500.
    # R1 = V1
    G90 G94 G17
    G20
    G28 G91 Z0.
    G90
    T2 M6 (Put tool in spindle for warm up)
    S+R1 M3
    G4 P1000
    M5
    G28 G91 Z0.
    G90
    G53 Y9.75
    M30
    Sep 2011
    40
    Re: Variables sub routines?
    Bump, any hints?
    Jan 2015
    417
    Try this program tested on my Fadal Both Format 1 and 2
    N1O3456(WARM UP)
    N2L100
    N3S+R0M3
    N4G4P1000
    N5#R0=R0+500.
    N6L201
    N7M17
    N8L200
    N9G0G90G17G80
    N10G53X-0.025Y0
    N11F100.
    N12X-0.025Y0I-1.G2
    N13X-0.025Y0I1.G3
    N14G1
    N15M17
    N16M30
    N17G90G94G17
    N18G20
    N19G28G91Z0
    N20G90
    N21T1M6
    N22#R0=500.
    N23L120
    N24M5
    N25G28G91Z0
    N26G90
    N27M30
  1. Probing routines
    By popspipes in forum Tormach PathPilot™
    Last Post: 10-08-2018, 12:27 AM
  2. SHARE YOUR SUB ROUTINES
    By keen in forum Tormach Personal CNC Mill
    Last Post: 11-01-2015, 03:59 PM
  3. Help Making Sub Routines
    By PROTOTRAKFAN in forum Parametric Programing
    Last Post: 07-15-2008, 12:09 AM
  4. Sub Routines on VF3
    By Rocko1 in forum Haas Mills
    Last Post: 11-10-2007, 09:41 PM
  5. sub routines
    By earl in forum Fanuc
    Last Post: 03-04-2007, 09:34 AM
