586,043 active members*
3,926 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Setting up first axis step/dir on KFLOP/KANALOG - No 'C'-experience
Page 2 of 6 1234
Results 21 to 40 of 109
  1. #21
    Mar 2022
    70
    Re: Setting up first axis step/dir on KFLOP/KANALOG - No 'C'-experience
    The machine have two similar dc servo When i checked by Pot both act the same
    I checked the voltages
  2. #22
    May 2006
    4045
    Hi Andualem,
    Driver was enabled green led ON when I tried by Pot
    Try again. If it doesn't work the Drive must be bad.
    On the driver +DT & -DT encoder was connected originally
    Those are Tachometer inputs not encoder inputs. You aren't answering my questions.
    Omron E6B2-cwzix
    Rotary encoder ( incremental)
    Resolution 1000 p/r
    Search for specifications and manual.
    TK
    http://dynomotion.com
  3. #23
    Mar 2022
    70
    Hi Tom
    About Analog tachometer it count revolutions per minute igital encoder have out out put binary code for exact position
    Search for specifications and manual.[/QUOTE]
    I search on that
    Thanks Tom
  4. #24
    Mar 2022
    70
    Hi Tom
    Some one imported this machine from Europe sell to the owner as brand new
    Technician before me made many problem when they tray to fix ( they didn't know the problem it becomes worst)
    You know it's difficult to get kflop and kanalog here
    That's why I have to figure out everything before I plug
    Depending on driver pdf when I connect pin6 and pin8 ( the motor moves ) predisposition
    But when I use POT no movement ( when I did this I disconnected 6 & 8)
    I can't get any other information about the driver it is old
    I need serious support
    Please Tom
    I need support
    just keep it
  5. #25
    May 2006
    4045
    I think 6 and 8 must be connected for the Drive to be enabled and the POT to cause motor motion.
    TK
  6. #26
    Mar 2022
    70
    Thanks Tom
    I will go tomorrow night it is above 200km far
    To try again
    I prepared kflop and kanalog to replace the old controller
    I can send to you kflop & kanalog connection photo tomorrow morning ( here now the time is middle night)
    You know Tom It's good opportunity for me to learn in the other hand for the company It's a necessary they invest what they have on that
    The machine cost here is very expensive
    If you have some advice please tell me
  7. #27
    Mar 2022
    70
    Hi Tom
    On that pdf ( attached ) it says encoder,
    Did you see?
  8. #28
    Mar 2022
    70
    Hi Tom
    Thanks your right
    I figure out the wiring starting from your information
    I get tachometer connection inside servo motor
    So I connect with driver +/- DT
    The incoder was wired wrong and cutted inside the machine
    I start making wiring between encoder and kanalog
    The encoder connection wire is when I refer pdf it have 3 ( A, B & Z ) reverse phase and 3 not reverse out put and 0V , 5V and Gnd
    So I think kanalog haven't 5V out so I think I have to use external power supply
    And from the 3 phase z is the full square signal
    A and B inputs
  9. #29
    Mar 2022
    70
    Hi Tom
    Thanks your right
    Kanalog JP1 and JP2 encoder inputs are A and B So if I use only A & B, is that okay ?
    I can attach the connection schematic to get suggestions
    As a beginner I have to get some guidance
    Thank you
  10. #30
    Mar 2022
    70
    Hi Tom
    This is what I try to make the wiring
    I have to edit limit switches connection
    I read on dynamotion book connection in parallel each axis
    And I need some initial points how I start make tread
  11. #31
    Mar 2022
    70
    Quote Originally Posted by Andualem View Post
    Hi Tom
    I can't attach xps file I will convert to pdf to send
    I take picture from the PC
  12. #32
    Mar 2022
    70
    RA (reverse Phase A output)
    NRA Non Reverse Output Phase A
  13. #33
    Mar 2022
    70
    Is that possible to make new thread without connecting motor and driver
  14. #34
    May 2006
    4045
    Hi Andualem,
    Sorry I don't understand most of that.
    Yes if you don't need the Z index pulse it doesn't need to be connected.
    TK
  15. #35
    Mar 2022
    70
    Hi Tom
    First I thank you
    I make the connection I use external 5 V for the encoder
    I finished the wiring for two axis
    Now I start working on software
    I install Kmotion 4.33
    I start reading about c programming
    I use kanalog
    To make the thread
    What are the steps?
    I want to show you my schematic but I can't attach here
  16. #36
    Mar 2022
    70
    I want to make with understanding step by step
    i try to write init.c but I'm not sure before this i suspect i have to do other things
    i need to know steps from the first i will study after that
    i use Kenalog JP1 encoder input
    JP11 out put for the +REF and -REF
    JP15 for Limit switch
  17. #37
    May 2006
    4045
    You might have used the +5V from Kanalog.
    Please use the later Test Version 4.35f
    To make the thread
    What are the steps?
    Not clear what you mean. First get the axis to work.
    Why not?
    Please read the steps here.
    TK
  18. #38
    Mar 2022
    70
    I connect 5V and 12V only on kflop
    Kanalog JP 8 when I measure 5V out I can't get ( when I check the voltage I didn't load any program in Kmotion )
    Is their any input supply voltage on Kanalog?
    OK thanks I can change with 4.35
    I was confused, after I make the wiring I load init.c and
    Configuration I tray to move . It was not clear for me
    I get some hints from your attach
    I didn't load KanaloginitialPID.mot, I have to do that
    Why not?
    When I attached before their was attach option in this page now their is no option
    Regards
  19. #39
    Mar 2022
    70
    Hi Tom
    I can't attach here, what shall I do ?
  20. #40
    May 2006
    4045
    zip it
    TK
Page 2 of 6 1234
  1. Kflop with STEP/DIR output
    By funding33 in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-01-2021, 04:49 PM
  2. KFlop to step/dir spindle
    By macona in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-14-2017, 09:06 AM
  3. KFlop how to configure spindle as Step and Dir No output for DIR
    By vetsen in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-08-2015, 07:08 PM
  4. KFlop with KAnalog Step and Dir for Yaskawa SGDH PULS/SIGN inputs
    By DeanW in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-02-2013, 08:37 PM
  5. Kflop Dir / Step setup time
    By BobKinsman in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-16-2012, 12:10 AM
