586,104 active members*
3,332 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > 1965 Makino Vertical Milling Machine - Model KSAM
Results 1 to 3 of 3
    Jun 2007
    4
    I recently acquired a very old Makino Vertical Milling Machine, Model: KSAM, Manufacture Date: Feb 1965. Yes..this is really old. I was wondering anyone had any experience with old Makino mill. The wiring is messed up on the back, i have to fix the wiring. i have no clue of the schematic. Any help or your experience is greatly appreciated. I was wondering if it is possible to run using single phase (110 V) using some phase converter.
    Apr 2007
    38
    Quote Originally Posted by silica View Post
    I dont know much about the wiring on the Makinos but I can remember back in the day working on one from the early eightys with a 6M Fanuc control and a BT 50 Taper and what a workhorse it was. Makino still makes good stuff.
    Kel1
    Jan 2008
    7
    makino mill
    Hi I am glad to here someone else took on a makino retrofit. you can see my mill on myspace [email protected]. yes i retrofit this big mill, or still working on it lol. is your spindle motor dc? mine is, and the field has 22 ohms resistance. I hooked it up in series and put a large potentiometer parellel with the field it works but will not stop. the motors got fitted with encoder where the resolver was. look at my myspace. I am stuck getting the pull knob stuff to work. do u have any schematics? ttys jeff
  1. Mori Seiki Dura Vertical 40 x 20 Model 5100
    By highspeedmike in forum Haas Mills
    Last Post: 06-26-2010, 01:44 PM
  2. fanuc 6m on Makino machine
    By samcaoly in forum MetalWork Discussion
    Last Post: 01-16-2007, 09:01 AM
  3. Help any suggestion spindle brand/model for Alumn/wood 3D cutting Milling ?
    By Calico in forum Uncategorised MetalWorking Machines
    Last Post: 08-30-2006, 10:15 AM
  4. anyone can machine this model?
    By designhawk in forum ArtCam Pro
    Last Post: 06-02-2006, 08:09 PM
  5. ACROLOC series 10 Vertical Milling Center CNC
    By DieGuy in forum Uncategorised MetalWorking Machines
    Last Post: 07-20-2005, 11:12 PM
