Originally Posted by
74BurkeMVN
I'll try to better describe what I run into....Some things I make require more than the 10 tools in the ATC and when a tool that came from the ATC is finished and a manually loaded one is called for, PP puts away the ATC tool and then requests the manually loaded one. Fine & perfect because at the ATC tool change height, there is lots of room to insert a tool. However, when that manually loaded tool is finished, if there happens to be another manually loaded tool requested, the machine just retracts to clearance height (like every other tool) and waits for the change there. I have always been happy with the default 0.400" clearance height in F360 as it keeps "Z" time to a minimum. Unfortunately, 0.400" isn't enough to change a manually loaded tool. Seems to me, PP should be smart enough to recognize this situation and just Z+ far enough up to change tools.
