Hi
I have this servo drive rs1a03aa sanmotion
Can anyone tell if it support pulse/dir commande or cw/ccw input
Hi
I think it will take pulse/direction input.
https://www.datasheetarchive.com/pdf...N%2520rs1a03aa
Jim Dawson
Sandy, Oregon, USA
That's a good question. I am not really sure what that says. I guess I would try step/direction and see if it works.
Jim Dawson
Sandy, Oregon, USA
most servo drives that accept digital input commands will accept three different modes:
1) Step/Direction....using the terminology in your manual Symbol/Pulse Train
2) CW/CCW....using terminology in your manual Forward Pulse/Reverse Pulse
3) Quadrature....using terminology in your manual 900phase difference two phase train
So provided you program the drive to accept option 1) then your parallel port will drive it fine.
Note that Mach3's parallel port has a default kernel frequency of only 25kHz, and thus the max Step rate will be 25kHz, meaning that you will not be able to exploit the servos high resolution
without limiting its maximum speed.
An external motion controller with a max pulse rate of at least 100kHz, but better 500kHz would be required to have med-high resolution AND max
rated speed of the servo.
Craig
Depending on the computer being used Mach3 can have a Kernel output frequency of 100KHz the average computer can do 75KHz without any problems I have tested Mach3 with the Kernel set at 100KHz and it worked ok, but I would not rely on it 100% though, testing would be ok, up to 200KHz is enough for most servos the Op his servo seems to have a max of 150KHz so 100KHz will be fine
An external motion controller is always going to be better, a UC100 would work very well for his servo
Mactec54
Hi Craig , thanks for your interaction
So from your answer i understand thati sould choose option 1 ( symbol+pulse train ) and wire it with the mach3 board
I have another question
I have done some research and i found that any servo drive have to pins( alarm ,and servo on ) that should be connected to vdd (5or24v) but i can't find those two pins (pics in attachments)
The inputs can be programed for many functions. Many times the default setting for Input1 (CONT1) is Drive Enable.
You really don't need to use the alarm output, but any of the outputs (OUTn) can be programmed for many functions.
You need to find the programming manual for the drive.
Jim Dawson
Sandy, Oregon, USA
page 5-17 of the manual:
Group8 parameter, page 11, value=02 for Step/Dir
page 5-24
GroupA parameter pages 0-07,10, these are the general purpose digital outputs, one or more of which can be used as an alarm. In sophisticated control systems there may be several alarm conditions,
some of which require an Estop, but others may require operator intervention. I suspect that with a parallel port you will have that few inputs available that you will not have multiple alarms per servo, in fact you
might not have enough inputs for one alarm per servo.
page 5-22
Group9 parameter pages 00-05, these are the digital inputs, including 05, Servo On, and 02, Alarm Reset. You will have to energise at least S_ON to enable the servo, that could of course be commoned to
all servos on the machine. You will most probably want the AL_RST input, so that if a servo faults you can reset it. It will reset with a power cycle but its a PITA to cycle servo power just to overcome a fault.
You will get a lot of alarms especially when setting up, once in service hopefully once in a blue moon. You could common the AL_RST input to all servos.
In the years I used Machs parallel port I found only a few PCs that could run at 45kHz, one or two only that could do 65kHz, and never had one PC that could do 100kHz reliably, your mileage may differ.Depending on the computer being used Mach3 can have a Kernel output frequency of 100KHz the average computer can do 75KHz without any problems I have tested Mach3 with the Kernel set at 100KHz and it worked ok,
Then I bought myself an Ethernet SmoothStepper, and it runs an 4MHz!! My current mill uses servos and I've set the resolution (electronic gearing) such that the linear resolution is 1um, but can still
get 5000rpm from the servos or 25m/min rapids, and that requires a Step pulse rate of 416.66kHz, and the SmoothStepper/BoB handles that no trouble. The differential inputs to the servo run to 500kHz.
page 9-1
The open collector inputs may have a limit of 150kHz, but the differential input (Step/DIR) has a limit of 5MHz, and the quadrature input has a limit of 1.25Mz. To take advantage of the servos
resolution AND maximum speed the high frequency signalling is required and very amply provided for......5MHz!!!
Craig
I have no experience with NC studio. From the picture it looks like there is a big micro-processor and maybe and FPGA as well, which would suggest that its way more sophisticated than just
a PCI-to-parallel card, and may in fact be a genuine motion controller. If it is a motion controller then it may well have high speed outputs. That the outputs are via a DB25 connector certainly
does not mean a drastic speed limitation.
My understanding is that NC Studio is a separate CNC software solution and is distinct from Mach3. If, and that's a big if, I'm correct then the card you pictured has to be used with NC Studio
and won't work with Mach3.
Craig
I've looked through the manual and can only conclude that you can only program the drive by using software installed on a PC. Do you have the software and the cable
required to program the drives?
Craig
I would have thought that if it were possible it would be described in the manual, but its not. That's why I asked the question.But i think i can manipulate with the button on the servo drive
Is that correct?
My Delta servos can be programmed by pushing buttons but its slow, tedious an error prone. I gave it up as a bad joke and bought the cable required
to program the drive with a PC, vastly superior.
My Allen Bradley servo REQUIRES software to set-up, you cant program by button pushing.....and I had to buy the software.
I think you should do some research to find out, you may end up having to buy the software as I did. It wasn't the end of the world ($200NZD) but
I wasn't expecting to have to pay.....
Craig
