On my Omni CNC, when the OP breaks the light curtain or Hits the E Stop the Z axis crashes down 3-4 inches. Everything looks to be in tact electrically. What am I missing?
Bad Z brake maybe?
Jim Dawson
Sandy, Oregon, USA
That is my first assumption after getting panels opened up. Also might replace the cylinder why I have it all open. Hasn't been cleaned in years it looks like.
If it has a counterbalance cylinder, then that might be the problem.
Jim Dawson
Sandy, Oregon, USA
I have seen this on lathes with heavy vertical X axis where the hydraulic stop valve has failed.
I should add, this was on the counter balance hydraulics.
Albert E.
