586,060 active members*
4,328 visitors online*
    Burny 2.5 Controller
    I have a Burny 2.5 controller which is hooked up to RS232 and sheetcam. After adjusting the serial definition (SD50) variable on the service > system data menu from 2235 to 2135 (Changing from ESSI to WADR language), I have the communication working well.
    However, before I download a program to the Burny I have to change the variable every time as it resets to 2235. I've followed the manual, pressing enter twice, and tried powering off / on, but am faced with the same issue. How do I save the setting permanently?
    Many thanks in advance,
    Jim
    Re: Burny 2.5 Controller
    Managed to sort this out.... After setting SD50 I had to then select SERV97 - Var. Store function and then press the SHF key when the display shows "Warning check manual". This saves the new settings into the permanent memory.
    Feb 2022
    4
    Hi!
    What PC program do you use burny with?
  1. Burny 3 controller problems..Help!
    By Welderpaul in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-25-2020, 03:34 PM
  2. Burny 2.5 Plus Controller
    By mark23 in forum Want To Buy...Need help!
    Last Post: 11-18-2012, 12:27 PM
  3. Burny 2.8 controller parts
    By porky118 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 04-11-2012, 08:34 PM
