As I mentioned before its easy to tell by looking at the tool, no video required that's all it can do. And inside edge of insert cutting would have bad chip evacuation causing a number of problems to consider. What is the point of using a 5 inch dia or 3/4 dia insert cutting tool or any tool that is not designed to center cut to try and plunge cut?. Setting up a program with a tool table full of tool choices of insert tools that can plunge cut or other tools made for this. Why on earth would you want to or even consider this in a program? Its just a tool change that takes seconds to do and load and use the right cutting tool for the right job. I just dont see the point and size of machine or power has nothing to do with it. What am I missing here?
Edit. Never mind my cam software will not even allow this with that type of tool defined. It throws a tool holder collision error. I would have to turn errors off or it won't even post code for a tool choice that is not designed to plunge cut.
