586,094 active members*
4,137 visitors online*
    Laser fiber engravement
    Hello everyone,
    Hope someone can help me. I recently bought a Laser Fiber machine from China and I´m doing some test. I use Coreldraw to make some CE plate (identification plates for machines) and then, converting to PNG file I open in EZCAD software to engravement.
    The problem is that if I use a shiny metal, the laser only marks the black drawing but if I use metal not too shiny, then the laser makes the engravement also of the white background.
    Can someone tell me how can I fix it in EZCAD?
    Attached is one pic to show the test I have already done.
    Thank you in advance.
    Jun 2022
    Re: Laser fiber engravement
    Easiest solution is to export out of coreldraw as a vector file rather than a PNG. I use DXF, then add a hatch in ezcad.
    When you export as PNG the computer breaks the image up into a grid of pixels and the software adjusts the power for the darkness of the pixel. Even white still has some amount of power. You can change this in EZCAD, but you will be much better off if you use a vector. It will be faster and look better.
  1. Test-Run the 3015H Fiber Laser Cutting Machine - 2KW 5' x 10' Fiber Laser Cutter
    By automationtechinc in forum Automation Technology Products
    Last Post: 01-31-2022, 08:48 PM
  2. Replies: 0
    Last Post: 05-13-2021, 06:53 PM
  3. gweike fiber laser welding and fiber laser cutting machine
    By laserliu in forum Fiber Laser Cutting Topics
    Last Post: 06-28-2019, 02:59 AM
  4. Fiber Laser Engraver, Fiber Marking Machine
    Last Post: 07-18-2018, 10:39 PM
  5. AK10F- A Portable Fiber Laser Marking Machine for Plastic, Fiber and Metal Engineerin
    By aaronhernandez in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-29-2016, 05:35 PM
