586,036 active members*
3,664 visitors online*
Thread: Feed rate
    Feb 2022
    Feed rate
    I am working on a Bridgeport torq cut 22. Halfway through cutting out a part of the machine just stopped and gives me an error message that there is no feed rate specified. Any help would be appreciated.
    Dec 2013
    5717
    Re: Feed rate
    The only odd thing I see there is what I assume is a comment 'POS# 1'. Maybe the controller is trying to read this as a feed speed?
    If it is not required, then deleting 'POS# 1' might be helpful.
    Jim Dawson
    Sandy, Oregon, USA
    Re: Feed rate
    Jim,
    Start with waht version of software is on the machine. Look on Main startup page, upper left corner. Want to see ... 6.87 or 6.89.
    How are you writing the code: cam offline; Bridgeport's editor with help will force you to fill all parameters and not get this error; or just from memory.
    Can you post the code. cant see text in pict.
    Bart
    Re: Feed rate
    Jim,
    Bart again. I see the error. On line with G2. It is the remark delimiter character; specifically the line shows G2 ..... 'Pos#....
    The <'> character is not syntax legal for a remark in Bridgeport world. Bridgeport uses <;> semicolon. change to G2.... ; Pos#
    Bart
  1. Steppers stall/oscillate at low feed rate. High feed is OK.
    By pfpmeijers in forum Stepper Motors / Drives
    Last Post: 02-17-2018, 07:12 PM
  2. feed rate vs override feed rate
    By Mooser in forum Tormach Personal CNC Mill
    Last Post: 08-16-2017, 09:26 AM
  3. feed rate and plunge rate help required please
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 12-07-2015, 09:30 AM
  4. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  5. Feed Rate and Spindle Rate for this cut?
    By DroopyPawn in forum MetalWork Discussion
    Last Post: 11-22-2007, 06:12 AM
