586,116 active members*
3,442 visitors online*
Results 1 to 5 of 5
    Nov 2013
    402
    Engraving problems
    I'm trying to engrave large 2.5" letters with the pre-set TORMACH engraving fonts on my 770..
    But, the pre-set fonts will mill around the outside of each letter, and then around the inside of each letter, creating two lines.
    I don't want that.
    I would like only a single line for each letter, so I can use a ballnosed endmill down center of each letter.
    How do I correct this?
    I've tried every font, and they all use inside/outside dual lines for the lettering.
    HELP!!!!!
    Dec 2013
    5717
    Re: Engraving problems
    A font with a .shx extension is single line.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2014
    1780
    You just need a single line font, there are a few. I use the one that came with Rhino, its good for part numbering etc. and I use some specialized ones as well. that I found on the web.
    Single-line fonts
    mike sr
    Nov 2013
    402
    THANKS PopsPipes!!
    I installed STICKFONT V1.1 on my old, beat up laptop, and it worked great!
    Easy to install, and very easy & basic software to use.
    Saves your text right to G-code.
    Thanks a bunch!
    Jun 2014
    1780
    Youre welcome sir!
    I use single line for part numbers on small parts that I make.
    mike sr
  1. Laser engraving problems
    By ninainwa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-23-2019, 10:40 AM
  2. RE: Laser engraving problems
    Last Post: 08-22-2019, 04:49 PM
  3. Having problems with aluminum engraving.
    By 4iSteven in forum Engraving Machines
    Last Post: 10-15-2017, 11:35 AM
  4. Engraving problems
    By xfidex in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-22-2017, 11:23 AM
  5. Engraving problems
    By mpq1969 in forum Mastercam
    Last Post: 05-23-2015, 12:43 PM
