586,546 active members*
3,258 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > ATC Spindle rebuild help
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Aug 2015
    37
    Re: ATC Spindle rebuild help
    Quote Originally Posted by paragon61 View Post
    Maybe....in the center ther was a spot about .75" that was hard like metal it broke free with a chisel but I do not think it would have come loose otherwise...at least now I have a good starting point and like you said i will use proper coolant...whoever had this before me obviously did not...seller of "refurbished" insisted that it had been thoroughly gone over...NOT!...I cleaned up pretty good and used sleeve with rubber cord in joint and hose clamps to tighten just dry as test......sealed up pretty well right away...will redo with small amount of sealant at bottom tomorrow..
    Thanks again!
    Hi...after reassembling jacket ran pump...everything good there..now I notice after running a few minutes wires into motor from inverter getting pretty warm..around 90 plus...turned off..So when I got motor wires from motor were short to exit atc assembly..I extender with soldered joints...is that wrong.?..is it normal for those wires to be so warm?
    Thanks for any help..
    Rick
  2. #22
    15362
    Rick
    No, the wires should not change temperature, it sounds like you have the wrong Gauge wire to carry the Amps the spindle needs, or you have not setup the VFD Drive correct to suit the spindle
    If you run it to slow it will draw a large current this will overheat the wires, what's the specs for the spindle
    Mactec54
  3. #23
    Aug 2015
    37
    what I have is 120TD1825.5a 5.5 kw...18000 RPM...220V...600 HZ...20A
    Inverter is GT-7R5G-2
Page 2 of 2 12
  1. 1100m Spindle Rebuild
    By mxr662 in forum Tormach Personal CNC Mill
    Last Post: 12-29-2021, 07:14 PM
  2. 3-axis machine RC2130DH-ATC with double ATC spindle for UK customer
    By Roctech-Mercy in forum Roctech CNC Routers
    Last Post: 06-18-2019, 08:09 AM
  3. RapidTurn Spindle Rebuild
    By Tbkahuna in forum Tormach Personal CNC Mill
    Last Post: 04-14-2019, 01:36 AM
  4. price and who to rebuild spindle
    By billsnogo in forum Fadal
    Last Post: 11-16-2015, 02:37 PM
  5. ES-L8 Spindle Rebuild
    By big_mak in forum Okuma
    Last Post: 04-05-2009, 07:12 PM
