586,103 active members*
3,311 visitors online*
    Torque Wrench for collet nut
    Hello brilliant minds!
    So I'm fairly new to the cnc world and have been having trouble to a bit slipping. It's a 1/2" shank, 4" inch overall length, 2 fluted straight bit. THe collet is E20 on an 3hp spindle.
    I have run across a few threads that suggest just a torque wrench to make sure it's got the proper tension. Any thoughts on this?
    It could be a combination of the bit being worn, the collet having some wear but perhaps it's improperly torqued.
    I don't have any troubles with a 1/4" collet or bits slipping.
    Running:
    Avid Pro4896
    34 NEMA
    Mach4
    ESS v277.1
    Thanks-
    Richard
    Dec 2013
    5717
    Re: Torque Wrench for collet nut
    A torque wrench might work. Google ''crowfoot wrench'' You can use these with torque wrench.
    I just normally use a 12'' Crescent wrench on my ER-20's
    Jim Dawson
    Sandy, Oregon, USA
    Just tighten it more. Use the two wrench method, and squeeze the wrenches together.
    I would think that a torque wrench would be difficult to use on a standard spindle. We use one with the tool holders on our ATC spindle, with a fixture that holds the toolholders on a bench. It's very easy to move a 500lb bench when tightening tools.
    Apr 2004
    326
    What Ger said, but also check to make sure that your collet is clean and doesn't have sawdust packed into the expansion joints.
    Quote Originally Posted by Kosh View Post
    Thanks everyone! Will stick with the two crescent wrenches method. I have a new collect on order -appears the one I'm using has some wear marks that might be causing an issue.
    Cheers,
    Richard
  1. Collet wrench C5
    By Kelsang-Lungta in forum CNC Tooling
    Last Post: 10-05-2020, 08:29 PM
  2. Collet wrench for a ??? collet nut
    By burnettm in forum Want To Buy...Need help!
    Last Post: 12-28-2012, 09:14 PM
  3. WTB Tree 310 spindle nut wrench
    By garychipmaker in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2011, 07:40 PM
  4. Theoretical Z repeatability with a torque wrench on an R8
    By xander18 in forum Benchtop Machines
    Last Post: 06-21-2011, 06:18 PM
  5. thrust bearing nut wrench
    By dreammstr6 in forum Bridgeport / Hardinge Mills
    Last Post: 12-25-2010, 01:55 PM
