586,080 active members*
3,655 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > clogged 5.5kw atc water cooled spindle
    Aug 2015
    37
    Hi...Just working on a repaired spindle motor and noiiced no flow at all thru water lines..opened up and stuck a drill down hole...went in about 2 inches...then solid..both holes..should that need to be drilled?
    Thanks for any help..
    Rick
    15362
    Re: clogged 5.5kw atc water cooled spindle
    Quote Originally Posted by paragon61 View Post
    Rick
    No there are baffles going around the whole spindle body, you can't drill through, they get Electrolysis Corrosion build up, if you don't use and anti-corrosion in the coolant, you will have to let it soak with something to get it clear, you may find something in an Auto store that will help to clear it out.
    Mactec54
  1. Looking for guidance on new 1.5kW Water cooled spindle
    By rcheli in forum Spindles / VFD
    Last Post: 04-09-2019, 04:05 PM
  2. Chinese 1.5kW, water cooled spindle and controller.
    By Pader in forum Drilling- and Milling Machines
    Last Post: 10-20-2017, 02:07 PM
  3. Clogged water-cooled spindle
    By Cam96819 in forum Spindles / VFD
    Last Post: 11-11-2016, 12:37 AM
