Hey guys. First, I'm brand new here... so if I'm posting in the wrong part of the forum, please let me know now.
Getting to the point; I bought a nice used machining center about 25 years ago, but never actually got around to using it. I brought it in, set it up, hooked up the air and electricity, played around with it a little, but I didn't understand how to program it at the time. Then I got busy with other things (I'm sure you all know how that is), and it just ended up sitting there unused for years.
Anyway, now I have a couple of other (previously manual) machines here in the shop that I have subsequently converted to CNC control. Because of my experience with them, I know enough at this stage to operate the machining center, and I have work for it as well. However, although this machine worked fine when I bought it, now the control is totally dead and unresponsive. Well... almost totally... when I flip the toggle switches on, the corresponding pilot LED will light up... but that's the ONLY indication of life on the control itself.
I would add that when I turn on the main disconnect, the hydraulic pump comes on immediately, along with the automatic lubrication pump and a couple of fans. Note that I have no control over any of this activity either, other than turning the main disconnect on or off.
So finally my question: Are any of you knowledgeable enough to guide me through a troubleshooting session on this particular control? And if so, is anyone willing to volunteer the time?
Richmond
