586,308 active members*
3,848 visitors online*
    Mar 2022
    Okuma lb15 II problem
    Hello i have a problem when i start my okuma lb15II
    It says 1-1 cpu alarm bus error
    The access address=fff83227
    What is the problem is there a broken card or something
    Apr 2009
    1262
    Re: Okuma lb15 II problem
    Card, cable or connection. Check connections first. It’s not uncommon that reseating the connections will often cure the issue.
    Reseating cards is also worthwhile.
    Which control?
    Experience is what you get just after you needed it.
