586,745 active members*
6,252 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > CAM software that is capable of diagonal finish lines instead of X or Y only
    May 2020
    4
    Just curious to know if anybody knows of a CAM program that can do diagonal finish instead of only a parallel in the X or Y, it would be XY with a Z component to control height...
    I'm interested in do some checkering on gun and knife grips, and a diagonal finish routine would be ideal for that... all that would be needed is a V bit and using the appropriate spacing.
    1230
    Re: CAM software that is capable of diagonal finish lines instead of X or Y only
    Freecad can,believe it or not,the default setting is 45 degrees and it has to be altered if you want to cut parallel to the X or Y axis.Many other programs will allow you to specify the angle at which passes are made but not all will make it easy to incorporate a Z element as that put you in 3D machining territory.
    15362
    Quote Originally Posted by BillNumber1 View Post
    You can do this in any Cam program its no more than doing a drawing of the part you want to crosshatch
    Mactec54
    Nov 2013
    4451
    Fusion 360 will produce angled toolpaths, curved toolpaths and many more.
    It free to hobbyists and startups but has some limitations applied. An annual subscription is about $500/year. That gets you ALL the 2D toolpaths and some of the more basic 3D toolpaths, and they have just recently added
    coordinated four axis and indexing five axis still on the entry level ($500PA) license. Full five axis, collision avoidance etc are another step over the basic subscription.
    Craig
    Apr 2003
    1357
    The MecSoft products can do this too.
