586,076 active members*
3,893 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Sliding door rail replacement
    Apr 2011
    I need to replace a bottom door rail on one of my Fadals. The round bar is not round anymore and it causes the bearings grind over and actually seize after a while. I know it is 5/8" in diameter but which material ( grade) should I buy as replacement? And also, how difficult it is to push the old one out and install new one?
    Apr 2014
    345
    Re: Sliding door rail replacement
    Quote Originally Posted by pavel569 View Post
    Most of the ones I’ve seen just seem like cold rolled steel but I’ve never seen a brand new machine.
    I bet some chrome plated shafting would hold up better.
    Make sure the bearings are all good in the sliders aswell
    Jan 2015
    417
    Its just 5/8 steel tubing just as Ian said. Easy to change just remove/loosen the collar at the ends with a allen wrench. Slide out and slide new one in place
    Jul 2005
    100
    Just rotate the shaft 180 deg. should be good for the next 20 years or so.
  1. 440 sliding door project
    By Tigster in forum Tormach Personal CNC Mill
    Last Post: 07-28-2022, 07:37 AM
  2. What part am I looking for? Some kind of sliding rail..
    By Jeep07 in forum Waterjet General Topics
    Last Post: 10-13-2010, 10:34 PM
  3. Sliding door tracks and rollers
    By Apples in forum Waterjet General Topics
    Last Post: 06-11-2004, 01:34 AM
  4. sliding door and window tracks
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 04-11-2004, 02:51 AM
