586,082 active members*
3,918 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Lathe LNC8 :907 alarm C lube flow 1
    Mar 2022
    Hey
    Just recently I had alarm come up on my LNC8 lathe showing a 907 alarm C Lube tank flow 1, thus far what I've been told is the tank has been replaced along with the manifolds, any help in clearing this alarm would be greatly appreciated, and the last maintenance guy said the operator got into the lube parameters and changed them around so does any 1 have a source for the parameters or a manual I could down load the fix this thing lol
    Oct 2009
    114
    Re: Okuma Lathe LNC8 :907 alarm C lube flow 1
    Oil viscosity number is correct. Check the slideway oil iso number.
    Apr 2006
    822
    check that the suction side of the pickup in the tank is clear.
    Had this same error on my machine recently and the pickup was dirty for some reason.
    A quick clean and no more alarm.
    Apr 2009
    1262
    There should be a page in the parameter Mode that specifies the lube settings...That machine should have the 700U control. I believe that the parameters are set for ON 30 seconds, OFF 5 minutes. If the system doesn't build pressure, you will get that fault. Track down why...leak, pump intake like broby says, vactra#2 or equivalant, parameter set too short.
    Experience is what you get just after you needed it.
    Jan 2009
    55
    Years back on my mid '90's Cadet...I had a 907 alarm.....and when I pulled the pump unit off the reservoir I found that the pump driveshaft drive pin had sheared...replaced the pin and it's been good for 20 years now.
  1. Okuma LNC8 65 Alarm-P
    By BC7208 in forum SERVICE FOR CNC-MACHINES
    Last Post: 09-10-2022, 07:37 PM
  2. Replies: 2
    Last Post: 04-08-2021, 02:14 PM
  3. Okuma Cadet LNC8 Alarm
    By 3DDonn in forum Okuma
    Last Post: 08-21-2013, 05:15 PM
  4. 907 Alarm-C lube tank flow 1/LB15
    By JonLed in forum Okuma
    Last Post: 03-30-2009, 05:42 PM
